I'm trying to cutout a portion of a roof below another dormer, I've already tried to make this one roof but the different eave heights make it very difficult so want to see if there is another easier way
I've attached a picture of the roof I am trying to create the cutout in, any help will be great ![]()
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Have you try the dormer tool?
I did try that but i need the entire portion of the roof there gone as it is a covered deck
Below is what the dormer opening tool creates
Use vertical opening
Then pick the edge of the roof
Once you finish, you should be able to create the hole. It is more flexible than the roof opening.
@Mbateman10 wrote:
I did try that but the soffit of the two roofs are at different levels
Then use a vertical cut opening to cut the main roof however you want it to be.
