How to create curved wall with one end tilt and straight on the other?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
HeadbuttJ
862 Aufrufe, 4 Antworten
I want to create a wall as illustrated below. I dont know whether blend or sweep should be used and how. Thanks.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: HeadbuttJ
Create a mass form then create walls by faces.
Nachricht 3 von 5
Revit 2021?  If so, you might be able to get there with a Slanted Wall. FWIW.
Slanted 20 degrees:
Nachricht 4 von 5
jbrazier
Did you try using a Model - In Place blend?  Create a shape for the Top and a shape for the bottom and it will morph.  Something like this:
Jon Brazier
Director of Production Technology
O'Donnell & Naccarato
Philadelphia, Pa.
Nachricht 5 von 5
HeadbuttJ
als Antwort auf: barthbradley
Can I just slant one side of the wall instead of both sides?
