How to create curved curtain wall
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
HeadbuttJ
1909 Aufrufe, 4 Antworten
I created a arbitrary form and would like to make curtain walls following the form. I could edit wall profile of the sides but do know how to deal with the front. How can I create that? Thanks.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: HeadbuttJ
With masses
Nachricht 3 von 5
syman2000
You may want to use curtain system. Select the surface of the mass and it will auto generate the curtainwall base on the massing shape.
Nachricht 4 von 5
You could also select the Wall and press "Edit Profile" on the Contextual Tab and change the Wall's Profile.
Nachricht 5 von 5
