how to create arc frame with sweep
8 ANTWORTEN 8
Nachricht 1 von 9
728 Aufrufe, 8 Antworten
Hi dears,
kindly help me to create a profile with arc shape with sweep tool . because in the plan the path is curved and in the elevation its straight. i have attach the plan & front elevation actually what i need. its very urgent also my work is stuck due to this issue.
Or how to sketch paths in multiple work plane at a time?
frame elevationframe elevation bule circled is the profile & the red line is curved path.bule circled is the profile & the red line is curved path.
8 ANTWORTEN 8
Nachricht 2 von 9
joe_keogh
als Antwort auf: Anonymous
Hi @Anonymous
Are you able to upload images of the finished product?
I'm not sure I understand what you want
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
Nachricht 3 von 9
cyrankam
To draw sweep path that is not plannar use "pick path" tool. Look it up.
Nachricht 4 von 9
I don't understand what you are describing. Do you mean rounded Window Trim molding like this?
Nachricht 5 von 9
FAIR59
Create the sweep (with Pick Path) in 2 parts and join.
Nachricht 6 von 9
als Antwort auf: FAIR59
yes, this is the concept that I mean, top & bottom path (horizontal) curved & both vertical path are straight.
then a profile run through these path. can you upload a making video of this? because I want to know how its doing.
Txs
Nachricht 7 von 9
cyrankam
@FAIR59 If I may ask, why do you advise to make it out of two sweeps rather then one?
Nachricht 8 von 9
als Antwort auf: cyrankam
Using two sweeps and join geometry is a legitimate approach because the sweeps are not deformed as if using one closed loop sweep.
Nachricht 9 von 9
cyrankam
als Antwort auf: ToanDN
@ToanDN I see, thank you for answer, that is valuable info.
