I want to create a view like this but I dont want to edit my wall profile or cut the slab into those funky shapes. Is there a easy way to do so.
I
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Hi @Anonymous
I see that you are visiting as a new member. Welcome to the Autodesk Community! ![]()
Did you try the split segment tool?
After you split the section, you can divide unto further segments and resize them.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Thanks ,
Split element cuts the wall vertically or horizontally in straight lines That tool does not help to complete this activity.
P.S : I dont want to edit my wall, I want to create a view is that achievable?
Hi @Anonymous
I see what you are saying. Can you share a file to test this profile?
Viveka CD
Create parts from the wall, split parts and draw the zigzag splitting line, hide the one you need to hide to reveal the interior.
