How to create a sweep with short path?
Sleepingfish_Kuo
Sleepingfish_Kuo
this is orginal model, And I want this below.
Is there any other method except rewriting it as an extrusion component?
eizinmyat
How about using swept blend? If you have two different cross sections and a path, you can create using swept blend. You can also use void for cutting unrequired parts from the top or section views.
I hope it helps!!
Happy Optimizing!!
Ei Zin Myat
Technical Sales Unit Engineer
ONESTRUCTION Co., Ltd.
[email protected]
Create overlapping two sweeps and join them.
Simon_Weel
The problem isn't the path, but the direction of the profile - it folds in on itself and that's a problem.
RDAOU
@Sleepingfish_Kuo
When the length of transition/path is less than 1xProfile Width (ie: a=b or a>b) you are less likely to be able to use a sweep.
Your best bet would be to work with 2 sweeps and joining them as suggested by Toan.
Sleepingfish_Kuo
I got a shape with this part lost when using two separated sweep.
... I'll use extrusion to instead some of them until find a easier way.
RDAOU
@Sleepingfish_Kuo
Considering that you have used Pick Path, you can simply do the following:
  • Switch to Wireframe to see the lines you have used to pick path
  • Stretch or Align and lock as needed
  • Use Join Geometry
See GIF Below
