How to create a sloped work plane in revit
Message 1 of 8
Hi all,
I'm trying to create sloped legs for a table but I can not find the way to create a specific sloped work plane in Revit. I found a family of a table already created to check how to do it but still can't find a way to do it.
You can find below a screenshot showing which is the sloped work plane that I want create. I've attached the revit file too.
Please, if anyone knows how can I manage this, let me know. Many thanks in advance._Screenshot sloped work plane.JPG
Accepted solutions (3)
Replies (7)
Message 2 of 8
FGPerraudin
Hi @Anonymous,
You can create sloped reference planes in elevation views, and then draw on them or use them to host extrusions, sweeps, etc.
What you show us is the grid that is used to draw.
To do that follow the next picture:
(1) draw a sloped reference plane in an elevation view, name it slope (create > ref plane)
(2) create you sweep and set the construction plane to the sloped ref plane
(3) click on the "show" button to show your construction plane. you might need to zoom to fit (ZF) .
Hope this helps,
François-Gabriel
Francois-Gabriel Perraudin
BIM management and coaching
Message 3 of 8
kadmonkee
if you create a section or elevation view
find a start point (typically the level as a base)
draw a reference plane in the view give the angle you need then name the reference plane so you can now associate elements to the plane
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 4 of 8
I guess you want to chop the table legs off at the sloped workplane, yes? If so, after created the workplane per above suggestions, draw a void on that workplane pointing down, and use it to cut the legs.
Message 5 of 8
Alfredo_Medina
How would you move that workplane if the table needs to be wider or longer? I guess that is the main question in this case.
Message 6 of 8
Alfredo_Medina
@Anonymous
I think that a better approach for making this family is to build a form, a truncated pyramid, not visible, to be the host for the sweeps of the legs. Something like this:
  1. Create a skeleton for the truncated pyramid that will be the host for the path of the sweeps.
  2. Create the truncated pyramid with the Blend tool.
  3. Create Sweep forms using "pick path" on the edges of the truncated pyramid.
  4. Using the same circular profile family, complete all the legs as sweeps.
  5. Using a nested family of a truncated cone, add the rubber caps for the bottom of the legs.
  6. Optionally, add a frame to hold together the legs, and add a counter top.
  7. Load into project and edit parameters at will.
Message 7 of 8
Thanks to all of you for your replies. Finally I've found the solution and it is more simple than I was thinking. Basically it is creating 2 different work planes.
1) Create 1 work plane based on a reference plane (blue) with an angle
2) Create a section paralel to that reference plane
3) In the section view, create another work plane based on a reference plane (red) to be possible place the extrusion for the table leg
4) Orientate a 3D view to the last work plane (red) to be possible draw in real dimensions
Silvia
Message 8 of 8
Doing it based on a form as @Alfredo_Medina should be easier.
But if you want to use reference plane, you only need one plane to model a tilted leg.  After you create the reference plan showing in Red below, you can model a sweep and draw the sweep path directly on the plane at the angle you want.
