How to create a rotating sweep
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
686 Aufrufe, 1 Antwort
Hi, I'm trying to create a quiet revolution wind turbine for my project and I'm struggling to create the turbine blades (I've attached an image for reference). teaserbox_22410216.jpg.png
I'm trying to create the blade by creating a sweep profile but it won't seem to rotate around the central pole and I'm not sure what to do to fix it. I've attached another image with as far as I've got.
Any help would be greatly appreciated!
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
Hello! I've managed to recreate what your looking for using a sweep blend. (although i wish id made the second blend a bit higher as it doesn't look quite right..) The path of the sweep is the radius of what you require then the two ends of the bled are the start and end height. I've attached a few images below.  Hope this helps!
