How to create a railing and handrails with slope in Revit?
mairh_tsek
Message 1 of 8
mairh_tsek
Hello all,
I want to create a railing with slope as you will see in the image below.
I edit the family of thr baluster but I dont know how can I give the same slope to the handrails.
Also I want the railing to start lower.
Do you how any solution how I can do these?
Thank you in advance!
title renamed for clarity by @Viveka_CD
Replies (7)
Message 2 of 8
Ilic.Andrej
Revit railings are vertical , so I suggest you create a family using line-based family template.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Message 3 of 8
Ilic.Andrej
I created a line based family railing so you can see how it works. Its attached. Load it, go to architecture tab/ component, draw the railing, set the angle etc...
Andrej Ilić
MSc Arch
Message 4 of 8
Sahay_R
Try this -
to get this -
Rina Sahay
Revit Architecture Certified Professional
Message 5 of 8
aRcHiTeCt.JM
..... hi @mairh_tsek
.... keeping your own railing family
.... to get to that inclination
..... go to your railing
.... and offset each and every of those components
.... you will get the result you are looking for
.... if you can upload the railing you are using we can fix it
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 6 of 8
aRcHiTeCt.JM
.... something like this
.... attached .rfa
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 7 of 8
mairh_tsek
Thank you for your time!
The offset for the rails works fine but how can I give also an offset to the Top Rail? (Image 1)
Also how I can give a bigger space between the end post and cornet post? I tried many times to change the equivalent number but nothing happens. (Image 2)
Find in the attachment the Railing.
Thank you!
Message 8 of 8
aRcHiTeCt.JM
... go to East view
.... click on the railing (turn that blue)
... click edit type
....go to top rail and click on rectangular 50*50
... it will open another dialog
... there in construction hand clearance
... change the value from -25 to 175
aRcHiTeCt.JM
REVIT EXPERT ELITE
