How to create a Plot Stamp that references the floor plant level?
1 ANTWORT 1
Nachricht 1 von 2
318 Aufrufe, 1 Antwort
Hello, I´m trying to figure out how exactly add a custom Plot Stamp in Revit. The only info ive been able to find are related to adding only a date/time visualization. Nevertheless, what i'm trying to do is add the level of the current floor plant that is intended to be printed but i havent found a proper way to do it within the software. Is there an option that allows the user access to that information (like in AutoCAD) or the solution should be based on the creation of additional parameters?
Best Regards,
José Ramón
MEP Engineer
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
Not a Plot Stamp like AutoCAD, but you can create labels in your Titleblock. And add new parameter fields for use in those labels.
...additionally, use can easily manage all these labels through a Sheet Schedule.
