I need to do a parapet at the end of the wall surrounding the building. What is the best and fastest way to do it?
Gelöst! Gehe zur Lösung
Gelöst von aRcHiTeCt.JM. Gehe zur Lösung
… hi @Anonymous
…. To add a wall type sweep do the following:
To add a parapet cap at the top of the front wall (and it might be nice to add a soldier course.)
To do this, we’ll use wall sweeps. You can add a wall sweep in two ways. They can be added to the wall type parameters so that they automatically show on all instances of the wall type throughout the model or you can use the Wall Sweep tool which allows you to add Sweeps to the model manually at whatever location you designate.
Make sure that the preview is showing. If it is not click the Preview button at the bottom to open it.
From the View pop-up at the bottom, choose: Section: Modify type attributes.
Please note that this button is only available if you are viewing the section preview.
In the “Wall Sweeps” dialog, click the Add button.
For the Material Choose: Concrete -Cast-in-Place Concrete.
From the “From” list, choose: Top.
At the bottom of the “Wall Sweeps” dialog, click the Apply button (see Figure).
If you wish, you can also edit the Exterior -EIFS on Mtl. Stud wall type the same way. Repeat the process to add the parapet cap to that wall type as well.
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
The method really depends on what you mean by "parapet". We generally model parapets as walls and they are placed on Levels just like any other walls.
Parapet:
Hi @Anonymous
You are welcome to ask questions in separate posts, this way you will fetch more answers from the community!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Do you mean to ask about parapet coping?
This is what I'm going for in the look. I need a truss with a chase for the duct to run through. I keep getting error messages. I can't seem to load diminisional lumber less than 2x10. Top and bottom cords need to be 2x6.
