I am trying to write a new "assembly description" file, however it seems that Revit does not read the lines that I write, for each line it gives me this result "the line is incomprehensible".
As a base I am using a file that Revit reads and this is the format I am using
(code)[space](description)
01 description
Does anyone know why that happens? Or do you know what type of encoding to use to create this file?
Gelöst! Gehe zur Lösung
Gelöst von tcardia. Gehe zur Lösung
