I have attached a fairly simple 2bay window family I created which I'm trying to convert into a flexible 4 bay window family with removable bays and mullions. I would like the window to be able to change from 4 equidistant bays to 1 and have the ability to turn off the inner mullions. I've tried researching this for awhile and can't seem to even begin to understand the off/on parameter. Is this possible? Thanks.
Solved by ToanDN. Go to Solution.
Option 1 (preferred): Create different families for different configurations: 1 bay, 2 bay, 4 bay.
Option 2: One family. Create mullions dependent from frame and give it visibility check boxes for 1 bay, 2 bay, or 4 bay. Mullions must not join with frame so you will see the join lines.
Option 3: One family. Create the entire frame and mullions for each configuration. Give it visibility check box similar to Option 2.
Option 4: One family. Create the entire frame and mullions for the most complex configuration (4 bay). Create voids that cut the mullions for other configurations. Voids cannot have visibility check box so you need to control it by dimension to make the void intersect with the mullions. It is rather complicated but it can be done.
I would go with Option 1. There is no need to overly ambitious and stuff everything into one family.
