I'm trying to create the following geometry:
Is there a way to create this in a Revit Family, it looks like a Revolve but it is square and revolves always have Absolute Radial Symmetry. I know I coud just do it flat, I'm just wondering if its possible to represent it with all those curved surfaces. I just want to clear any possibilities, before going to the simple route(Flat Extrusion with a curvy square sketch)
Thanks in Advance
You could whittle down a block to that shape. That is cut a solid with one or more voids.
Actually, start from a Revolve.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-791BBD4C-ABFA-40D7-9B4F-8C39F50164CE
Create the revolve then cut it with a void square with rounded corners.
it seems like in the corners the profile might be different a little wider.
@JsphH11 wrote:it seems like in the corners the profile might be different a little wider.
What's your point?
Just insert the image into a Model Family Template. Put one in Plan and one in Elevation and Scale them both the same. Then use Grid Method and Mirroring to reproduce the shape in Revit.
