HOW TO CREATE A CURVED DOOR FAMILY
8 ANTWORTEN 8
Nachricht 1 von 9
ngurearchitect
1187 Aufrufe, 8 Antworten
I want to create a curved door family to place on a curved wall. I understand the basics of family creation but create a curved door seems complex to me.
Tags (1)
Beschriftungen (1)
8 ANTWORTEN 8
Nachricht 2 von 9
ennujozlagam
als Antwort auf: ngurearchitect
just drag your door family into your curved wall?
Nachricht 3 von 9
ngurearchitect
Unfortunately the curvature on my walls means that solution does not work.
Nachricht 4 von 9
ennujozlagam
post part of your door and wall here so we check?
Nachricht 5 von 9
mhiserZFHXS
Is this an actual construction project or are you just modeling something? I have never seen a curved swing door in the real world before. I can find some images of curved pocket doors, but that's not what you have here.
Nachricht 6 von 9
You could model a curved door as an In-Place Component in the Project to fit a specific curved Wall if you don't want to build a parametric loadable curved door Family.  That might be easier for you.  Even easier, would be to embed a curved Wall Type that was the same thickness and materials as your curved door panel and call this Wall Type "Curved Door".  :zwinkerndes_Gesicht:
...I'm assuming that yours is a custom curved door since "curved" doors is not something you buy off the shelf. Am I reading you correctly? Yours are doors that will be specially built for your Project?
Nachricht 7 von 9
Out of curiosity, are these doors pocket or slider types?
Can you share a picture of the real thing?
Nachricht 8 von 9
dan_SAA
Maybe: https://www.c-sgroup.com/doors/acrovyn-curved-doors ?
also: dynamicfenestration.com Lamoureaux-Architects_Ocean-Bluff_VancouverLamoureaux-Architects_Ocean-Bluff_Vancouver-5
Nachricht 9 von 9
The principle is the same modeling any curved elements.  You control the radius and the width based on:
