How to create a curved centre line with no breaks
2 ANTWORTEN 2
Nachricht 1 von 3
911 Aufrufe, 2 Antworten
Hi there,
I'm currently trying to reproduce this centre line (an imported dwg) as a revit line/element, but seeing as revit cant do polylines I'm not quite sure how to create it. When I use multiple lines the centreline pattern starts and stops with each line so the pattern is inconstant. Any ideas?
^existing dwg line
Tags (1)
Beschriftungen (1)
  • Line
2 ANTWORTEN 2
Nachricht 2 von 3
constantin.stroescu
als Antwort auf: Anonymous
you can do it:
  • either by a series of continue : line - tangent end arc-tangent end arc-........-line
  • or if you intent to obtain a single entity , then use Spline by Control Points or Spline Through Points
Constantin Stroescu
Nachricht 3 von 3
constantin.stroescu
and a rough screencast showing both ways:
https://knowledge.autodesk.com/community/screencast/f50b9a08-61c0-4f33-9563-b928af03de69
Constantin Stroescu
