Hey!
I would like to see how much volume of material is in the walls, floors and beams... (maybe without having to make my own calculations!)
Is there a way I can do this in revit? If so, could someone explain to me in begginer (ish) terms please :))
If you click your element, you should see 'Volume' in the Properties.
With this, you can create a schedule (Multi-category) and apply 'Volume' as a field!
use a Material Takeoff Schedule : View >Schedules>Material Takeoff - if you want to have all then use Multi Category
Constantin Stroescu
Thanks very much for this!
Unfortunately though, in the list of scedule properties I am missing the option for volume...
Do you know why, or how to get it?
I have the same problem unfortuantely...
I am missing the option for volume from the list...
Thanks Toan :)))
And nowww,,, I have a long list with Category and material:volume....
Is there a way I could see how many of these I have... or a way to include TOTAL volume of this category part? (something like this??)
at the end i want to know how many m3 of columns, beams and flooring we are using
Thanks!
Play with Sorting/ Grouping, untick Itemize every instance box, and set the Material: Volume field to Calculate Totals.
