How to copy paste data quickly in revit schedule ?
Message 1 of 15
Is there any method than click each cell and paste the data ? I attached a screenshot, That i need to copy paste "plumbing" in each raw.
Eng. Pasindu | Civil Engineer
Accepted solutions (3)
Replies (14)
Message 2 of 15
L.Maas
No, that is why i created the Multiple Selections post in the Ideas forum.
To speed things up and depending on the needs I would create a Dynamo script.
Also note that a schedule is scheduling elements in a project, so in most schedules you can not just add rows as this would be adding elements to the projects
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 15
edwin.prakoso
I use this plugin: Export Import Excel. You can export the table to Excel, modify it in Excel then import it back to Revit.
Cheers,
Edwin Prakoso
Message 4 of 15
loboarch
If they are all the same family and type (which they appear to be), you could just select one in the model (or from the schedule), and then right click and choose "select all instances > in entire project" you could then fill out the "Comments" field and whatever you put there would be applied to everything selected.
Maybe not quite "cut and paste" but it would beat filling out each one individually.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 5 of 15
M_Perez
As pointed out by @loboarch you can change the value in model. If you don't want to change all of them, you can also select in the table the desired ones (they have to be consecutive) and then click in a view to change the value.
Message 6 of 15
loboarch
It might also be useful to point out when you provide values for "comments" the schedule gives a pulldown menu to fill out the field with previous values, so it would be a bit faster than typing every field with whatever you are filling in.  you can just pick from a list of previously used values.
Jeff Hanson
Revit Help |
Message 7 of 15
Corsten.Au
Hi
Create one more schedule to edit the data
SORT by Family, now you will have all the rows unique to family and changing
the data will update all the elements of that family in one go.. ( uncheck "show individual instance ")
this technique you can use for any schedule..
Trick is how you sort ..
Corsten
Building Designer
Message 8 of 15
@edwin.prakoso, I tried you said method. But it gives error as shown below. Please help me to solve it.
Message 9 of 15
Viveka_CD
@Anonymous Were you able to try the other recommendations by the experts?
Message 10 of 15
Beside from grouping and entering them on the schedule, you can select all the rows on the schedule, click on Highlight in model button to go to a model view and enter the value from properties.
Message 11 of 15
garcialuop
As expected, this is not possible with room tags. Once again, a process tha should be simple becomes a nightmare
Message 12 of 15
M_Perez
What are you trying to change from the room tags? If it is a value from the rooms, you have to select the rooms and change the value using any of the options explain before. The tags will update automatically!
Message 13 of 15
garcialuop
I have over 300 rooms, if i select room by room (first trying to find the cross and then ctrl+click) it takes an eternity. It is impossible to Right Click+Select all instances because Revit decided that should not be allowed. The only alternative is Excel.
Message 14 of 15
garcialuop
That definitely helped
Message 15 of 15
M_Perez
You don't need to find the cross. Instead of that if you mouseover the Room Tag and press Tab, will be possible to click the room.
Anyway, the best option for you is probably to do it over a schedule (like explained before) or insolate the category rooms. I don't get what your question is.
