Hi. I have a 4 story building. I am trying to render a few rooms and send them to someone who will render the rooms for me in 3ds max. I don't want to send them the entire file. Just the room or floor (preferably the room) so they can focus on that portion. Could someone walk me through this process? I know there's a way because I have copied people's links in my file before, but I have no idea the steps to do this. Screenshots/video or detailed write-out would be extremely helpful. Thank you so much!
You can create 3d view and use section box to crop the portion of the model. Then export that 3d view.
The other option is if you have a callout, you can set the 3d view to be the same view as the cropped
Go to to view cube and select the arrow
Select the view
Your 3d view will cropped
You can export as FBX or DWG. If you really want to save as RVT, then create the new sheet. Place the 3d view in the titleblock and export. This will export part of your model to new Revit file.
@KGARRETT5 wrote:Any recommendations here? It's grayed out when I try to save
Place it on a blank titleblock. Right click and then the save to file will appear.
