How to convert Precast stair to generic model
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
shuaib009
992 Aufrufe, 3 Antworten
How to convert Precast stair to generic model. I would like to make recess in landing for corbel as per the below sketch.
Below is the section for clarity.
Precast Panels are not shown in 3D image
3 ANTWORTEN 3
Nachricht 2 von 4
L.Maas
als Antwort auf: shuaib009
There is no straightforward way. You could export the stair as dwg from the project. Then you can load that dwg in a Revit family. Then you could use the standard family tools to model over (parts) of the stair.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 4
RDAOU
@shuaib009
Keep the stair as stair...you do not need to remodel it all
  1. Edit Stair >>> Delete the landing >>> Finish sketch
  2. Model the Landing as a Floor Slab...these you can cut with a void
Nachricht 4 von 4
shuaib009
smart solution. thank you.
