I have a huge 3D model file. Too big to handle !
How can I convert this file into ifc file and make it smaller size so I can link with revit model ?
Gelöst! Gehe zur Lösung
Hi @Anonymoush
I see that you are a new visitor. Welcome to the Autodesk community! ![]()
As the first step, I would recommend the below:
Best practices to follow when linking DWG files into Revit
Let me know if you have any questions.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi Viveka,
Thanks for your tips. It is really helpful in general practice to reduce the file size.
Is there anyway I can convert .dwg file into .ifc ?
Regards.
Dharam.
Hi @Anonymous
Hope that helps.
Viveka CD
