Please see the attached family. I'd like to know how to lock reference planes "Lip 1" and "Lip 2" to the geometry. I can't figure out how to align, lock, or constrain reference planes/geometry that are not parallel to the default reference planes/views. If there is a means of creating views within the family that are aligned to the reference planes I've created, that would be enough for me to proceed. This family was built with a generic family template from Revit 2022.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Get rid of all angled reference planes and add dimensions to the extrusion sketch (see revised file), or create ref lines to constrain the angled lips.
Easy-peasy, thanks! Is there a similar method that can be applied to a free form element - specifically an exploded ACAD import - of similar geometry? Although the 'dimensions within the extrusion sketch' method was a breeze, I'm inexperienced with reference lines (I've had a lot of trouble trying to get them to function as desired) and I'll be required to import some geometry representing light gauge steel components Revit cannot model natively.
