How to connect the end of a wall to non-90-degree aluminum glass (Curtain Wall) in Revit?
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
bobbywijya
204 Aufrufe, 3 Antworten
How to connect the end of a wall to non-90-degree aluminum glass in this case properly, please advise, Thank you so much!
3 ANTWORTEN 3
Nachricht 2 von 4
Simon_Weel
als Antwort auf: bobbywijya
Easiest way is to use a very thin wall, like 1mm, and draw that to the inside of the curtain wall. Then join the other wall.
If the 1mm-wall shows up too thick, you could use a filter to hide it.
Nachricht 3 von 4
bobbywijya
als Antwort auf: Simon_Weel
Thank you so much for the solution, that's exactly, will you mind showing me by video, if that's not a problem for you sir. Many thanks
Nachricht 4 von 4
bobbywijya
Anyway, i figured out the method you are using, Many thanks for the great solution! cheers!
