How to connect the beam to the column without gaps
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
Caed9
2151 Aufrufe, 10 Antworten
Hi, Revit community,
Is there a way to remove the gap between the foundation beam and the foundation column?
I already tried looking on the properties palette to see if there was an option, but all I see is y and z justifications.
I just want to remove the gap, could you please give me some advice on how to adjust it, I also tried changing the material on the beam to match the column, but the gap was still there. And when I tried to join them  I get a message that says that they are already joined.
Thank you
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: Caed9
Zero out the join cutback.
Nachricht 3 von 11
Nachricht 4 von 11
Betcha yours is reading "Wood". Choose "Concrete".
Nachricht 5 von 11
_Vijay
Try with beam/Column joint tool as in image.
Nachricht 6 von 11
Caed9
als Antwort auf: barthbradley
I tried editing the family but it was in concrete, I changed to precast concrete to match the column.
But the gap is still there
Nachricht 7 von 11
Man, I though for sure that was it.  Well, I guess no parade for me tomorrow. Arrgh!   Post the file if you want.
One more thought: any nested shared  components in this booger?
Nachricht 8 von 11
Caed9
hi, I fixed it with the start join cutback and end join cut back in the properties palette , I set them to 0.
Nachricht 9 von 11
That was the first thing I said! Yippie!
Parade back on?
Nachricht 10 von 11
Caed9
Thanks @barthbradley I was looking for that option in the properties palette and could not find it, I thought it was only for steel beams.
Nachricht 11 von 11
