I would like to Analyze the solar radiation on the building facade using Revit. But in Revit 2025, the solar analysis function is not found in Insight...The new Insight is all about carbon calculation.
Anyone has suggestion how to conduct solar analysis in Revit 2025? Many thanks in advance
Gelöst! Gehe zur Lösung
Gelöst von s.iwasakiSYTFM. Gehe zur Lösung
I will explain the procedure.
I hope this will be helpful.
Yes. It works. I found the hidden gem and am able to conduct the solar analysis now. Many thanks!
