How to combine two separate drawings with different units
How do you save two separate drawings with different units and scales into one. I need to upload two assignments to my teacher but they have to be in one file.
Please help.
A: inch
B: mm
if link B into A, choose unit = mm.  If link A into B, choose unit = inch.  Bind link when done.
p/s: Next time if you download models from the internet for you assignments, find the ones with the same units 😉
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community!Smiley Happy
Insert the link as suggested by @ToanDN
Image result for bind link tool in revit
  1. In the drawing area, select the linked Revit model.
  2. Click Modify - RVT Links tab - Link panel (Bind Link).
  3. In the Bind Link Options dialog, select the elements and datum to include in the group, and click OK.
  4. From the Contextual Modify|RVT Links tab select Bind Link.
    Revit 2012 revit link modfiy
  5. In the Bind Link Options dialog box, check on the items that you want to bring in from your project.
    Revit 2012bind link
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome.
chrisplyler
Print each drawing to a pdf file. Use Acrobat or Revu or another pdf editor to combine the two files into one multi-page file.
