How to combine movie file(mov, avi, etc) into RVT file?/ 動画FileをRVTFileに埋込む方法
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
514 Aufrufe, 2 Antworten
How to combine a movie file(mov or equivalent) into RVT file? /
If it is possible that a movie file can be conbined, which kind of file type can be accepted?
On the other hand, how to export walkthrough movie from RVT files?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
You can't import a movie into Revit.  You can export a walk-through using File - Export - Images and Animations.  If  a walk-through has been created you should see it here.
Nachricht 3 von 3
Viveka_CD
Hi @Anonymous
I see that you are a new visitor. Welcome to the Revit Architecture forum!Smiley (fröhlich)
@Anonymous  is right you cannot export a movie in Revit, the formats vary.
Please see how to Export a Walkthrough
Let me know if that helps with your issue.
