How to clear/reset project address/location for template creation?
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
zacharytbroussard
408 Aufrufe, 5 Antworten
I am trying to essentially clean up a project file for the creation of an office template. It's going well, but the project had an address assigned under the Manage>Project Location>Location tool, and I can't find anywhere online that describes how to clear this value. Is there a way?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: zacharytbroussard
Don't worry about it.
Nachricht 3 von 6
You can highlight the address and delete to restore <Default>.
Nachricht 4 von 6
RDAOU
@zacharytbroussard
Click the 3 Dots to edit or clear value
Nvm misread post
Nachricht 5 von 6
zacharytbroussard
als Antwort auf: ToanDN
I believe that this may have something to do with the functionality of Revit LT - I'm on LT, and my Location window looks different than that and I don't have the option to delete saved locations.
Thank you anyway though! This does seem like the solution, in Revit full version.
Nachricht 6 von 6
Check the REVIT.INI file settings...
The Revit.ini File | Revit 2021 | Autodesk Knowledge Network
