how to clean up stair stringer
5 ANTWORTEN 5
Nachricht 1 von 6
nasibeh.montazeri
381 Aufrufe, 5 Antworten
Hi All,
is there any one to help me how can I make one clean stringer in my stair? the outer stringer is clear but the inner one I can not connect these 3 different stringer together:
5 ANTWORTEN 5
Nachricht 2 von 6
mphungDCHNW
als Antwort auf: nasibeh.montazeri
First select the stairs set you want to edit go into a plan view and drag the middle channel in between the 2 red circles in your image drag accordingly  and you will the stringer join together.
Nachricht 3 von 6
How would they connect in real life?
Nachricht 4 von 6
nasibeh.montazeri
als Antwort auf: ToanDN
exactly like the otherside of the stair(outside stringer). I have problem just for inside stringer
Nachricht 5 von 6
Do you realize that is physically impossible with your current landing layout?  The only way to get it is with a U-shaped landing.
Nachricht 6 von 6
kh_jea
Indeed. Or turn off "end with riser" for the first run and "begin with riser" for the second run.
