How to change the properties palette
4 ANTWORTEN 4
Nachricht 1 von 5
736 Aufrufe, 4 Antworten
How to add new row in properties palette
for eg I attached in below imag
4 ANTWORTEN 4
Nachricht 2 von 5
ennujozlagam
als Antwort auf: Anonymous
maybe you can refer to this LINK . thanks
Nachricht 3 von 5
Alan.johnson1970
You really need to edit the family and add the instance parameters.
You can then edit the values as required.
AJ.
Nachricht 4 von 5
The link
AJ.
Nachricht 5 von 5
prfisher311
I have been having the same problem.
I am attempting to add a shared parameter (that is already associated with several families) to the Properties Palette for easier editing.
I reviewed the link provided and was not able to find a solution there either.
