How to change the grid extension from a scope in a plan ?
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
l.terribile
2312 Aufrufe, 11 Antworten
Dividing the general plan in 4 scope boxes, how can i change the extension of the grids in every single scope box  (to create a unique graphic presentation of the grids in the sheets) . I tried with propagate extend tool and it only works when in a view there is no scope boxes/cut applied on it .
Tks
11 ANTWORTEN 11
Nachricht 2 von 12
RobDraw
als Antwort auf: l.terribile
Grid lines extend beyond scope boxes and will be shortened automatically, hopefully creating a uniform appearance.
Rob
Nachricht 3 von 12
Assign a scope box to the view and grids 2d extent will be shorten accordingly.
Nachricht 4 von 12
RSomppi
als Antwort auf: RobDraw
Nachricht 5 von 12
d.huiskampQM9S6
@RSomppi Where do you find that parameter? i don't have that when i'm in my view. Or did you make it by your self?
Nachricht 6 von 12
RSomppi
als Antwort auf: d.huiskampQM9S6
I did not make it. I just checked '21 and '22 and it is not present in either. It must be a new feature in '23 or '24.
Nachricht 7 von 12
d.huiskampQM9S6
als Antwort auf: RSomppi
i think its only available in revit '24. In '23.1 you can't change it. Thanks btw
Nachricht 8 von 12
RSomppi
If you see it in '23, then your first statement doesn't make sense.
I can see in the image that it is grayed out. Did you check to see if it is a type parameter for the view type?
Nachricht 9 von 12
d.huiskampQM9S6
sorry, i mean i can't change it because its not visible at all.
Nachricht 10 von 12
RSomppi
Again, did you check to see if it is a type parameter?
Sorry, I connot check for myself as my '23 is not updated. We haven't had a need for it yet.
Nachricht 11 von 12
Simon_Weel
Totally off-topic. But anyway - screenshot Revit 2023:
Don't see it in 2022.
Nachricht 12 von 12
Yong-sung.choi
Grid to crop region Free add-in
https://youtu.be/gu_Q3HEyjvs
