How to change nested family params in the host family properties
14 ANTWORTEN 14
GELÖST
Nachricht 1 von 15
info
756 Aufrufe, 14 Antworten
Hello to all,
I am strugeling with a problem in my family file: see attachment Structural-beam.
I have nested the family Damwand into it, but I can get it connected by the host.
What I want is to control the height of the Damwand extrusion (same param-name as in the host) and the numbers of arrayed elements.
But when opening the host params, I don't see those 2 params of the nested.
I am quit new to Revit and searched the fora but didn't find a solution.
Can anybody help me out?
Thanks in advance!
14 ANTWORTEN 14
Nachricht 2 von 15
als Antwort auf: info
You need to create the parameters IN THE HOST  to drive the parameters in the nested family. You ASSOCIATE  the the two parameters together in the host.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/EN...
Nachricht 3 von 15
info
als Antwort auf: barthbradley
Thanks for the quick reply and link. I already looked at that page, but in my nested type properties I haven't the possibility to click on a button on the far right, because there is simply no grey button.
I can't figure out what went wrong.
When I make the height of the Damwand nested family the same param as in the host, it gives me a contraint error...
Nachricht 4 von 15
Make them INSTANCE Parameters (in nested Family).
Nachricht 5 von 15
info
Here are my latest files.... It seams me the easiest way to align the damwand nested to the ref planes at bottom and top in the host...?
Nachricht 6 von 15
Okay, so  I see your family. I'd do it a little differently though. I'd Array in the host, not in the Nested Family.  And, I'd constrain just the bottom of the Arrayed Element and associate it height parameter (Instance kind)  to a host parameter.  That not work for you?
Nachricht 7 von 15
info
Thanks for all the quick replies!
No, I couldn't make it work for me. Perhaps I am doing something wrong, because I am a newbe to Revit.
Can you please share that model to me, so I can have a look what I do wrong?
Thanks...
Nachricht 8 von 15
Nachricht 9 von 15
info
Thanks a lot for helping me as new-one in Revit!!
I now see how you did it...
I completed the family, but have one problem with a void on the end. See attachement if you are willing to help and know how to solve this?
I want to cut the last arrayed structure and placed a void on the end. But is doesn't cut.
I looked a lot on the internet and fora and saw that it has something to do with the order of the family.
If I see it well, the void won't cut, because the array is placed later?
Do you, or something else have an idea how I can solve this?
Thanks a lot again!
Nachricht 10 von 15
I'm looking at you family and trying to understand what it is that you are trying to cut out. That flange tip?  You can't.
Nachricht 11 von 15
info
Yes that curved flanged wich is arrayd.
When it's impossible to cut that this way, my family failed how it's now made... :enttäuschtes_Gesicht:
Nachricht 12 von 15
The array can't be cut in this way,  but you could end the array with a minus one and then model a separate "Damwand" just for the end.  You could then cut that one with a void.  You could even parameterize the cut depth to meet different conditions. But, that's a workflow that is hard to explain.  Do you get the concept though?
Nachricht 13 von 15
Mikeymore
I made the changes and got it working !!
Thanks for all the help!
Cheers...
Nachricht 14 von 15
als Antwort auf: Mikeymore
What did you do?  What I said, or did you come up with another way to do it?
Nachricht 15 von 15
Mikeymore
No new insights, just exactly how you suggested.
