How to change local files path directory when syncing?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
dmena.arq
493 Aufrufe, 4 Antworten
How do you change the path into which local copies are being saved when syncing?
I'm unable to synchronize my collaborative model since my C unit is already full.
Thanks!
Beschriftungen (3)
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: dmena.arq
https://knowledge.autodesk.com/support/bim-360/learn-explore/caas/sfdcarticles/sfdcarticles/C4R-is-i...
I would suggest to upgrade your local drive capacity instead of changing teh path.
Nachricht 3 von 5
RobDraw
A full drive can cause lots of problems. Get rid of stuff you don't need like temp files and old junk or get a bigger drive.
Rob
Nachricht 4 von 5
hmunsell
When was the last time you cleaned out your Local folder? the default path is listed below. I clean out my Local folder of old files regularly. They will just get remade next time you open your central model.
  • C:\Users\%USERNAME%\AppData\Local\Autodesk\Revit\<Autodesk Revit Version>\CollaborationCache
Howard Munsell
Nachricht 5 von 5
dmena.arq
Thank you all for your advice. I deleted all the temp files folder and the cache so I finally got some free space to work.
