How to change color of different Worksets per Sheet
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
RobertT6D9ET
4752 Aufrufe, 4 Antworten
I have a plan with different worksets on it. I'd like to have the walls to have different graphics per workset. How would I do something like that? Is it at all possible?
Tags (1)
4 ANTWORTEN 4
Nachricht 2 von 5
syman2000
als Antwort auf: RobertT6D9ET
Typically I would use filters. In the filters, I would select all the objects and then set it to workset.
Then you would set that workset with different line color.
Nachricht 3 von 5
Are you talking about Worksharing Display Settings colors?
Nachricht 4 von 5
RobertT6D9ET
als Antwort auf: syman2000
Thank you!
Nachricht 5 von 5
RobertT6D9ET
als Antwort auf: barthbradley
