it is a quite common concrete stair in the upper pic, I really don't know how to build it with Revit... . How to change the height of the 1st and the final step in the stairs tool...? APPRECIATE!
Pretty sure Revit will always make all the risers uniform. If you want to model something different you may need to make your own family or do a model in place family.
Landing detail:
The highlighted detail is not doable with the stair tool...it will be a straight cut
Otherwise,
Different Risers:
