How to carve void out from landscape topography?
2 ANTWORTEN 2
Nachricht 1 von 3
706 Aufrufe, 2 Antworten
Hi All,
Please see attached, screenshot relating to the following issue.
Is there a way to "carve"out of Revit's landscape topography almost like a "cave"effect?
Thank you in advance.
Wayne
2 ANTWORTEN 2
Nachricht 2 von 3
Ilic.Andrej
als Antwort auf: Anonymous
Use building pad
(Massing & Site / Building Pad)
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 3
Something like this Tunnel? You can get there by Exporting a Toposurface to DWG and then Importing the DWG back it into a Mass sketch environment. Once you've got this Mass, you can apply a Floor (w/ Variable Thickness) to it's faces. The Floor would be the material of the earth. Once you've got the Floor by Mass Face in place (now resembling a Toposurface), you can cut through it, or out of it, using void cuts. To learn more about this technique, check out this Link: http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2013/revit-for-architects/ab3340#ch...
