How to cancel permanent "apply area rules" in place area boundary command ??
18 ANTWORTEN 18
Nachricht 1 von 19
2281 Aufrufe, 18 Antworten
18 ANTWORTEN 18
Nachricht 2 von 19
als Antwort auf: Anonymous
The in-built "Gross Building" doesn't work for you?
Nachricht 3 von 19
NLARIOS121
Not really, I have to un check the box every time. I can't seem to find a way to set the default to "not checked"
Nachricht 4 von 19
als Antwort auf: NLARIOS121
Are we talking about the same thing? I'm referring to Area Scheme. What are you referring to?
Nachricht 5 von 19
NLARIOS121
When you go to the "Place Area Boundary" the apply area rules check box is on by default.
Nachricht 6 von 19
betsyjcole
I have this question too.
Nachricht 7 von 19
als Antwort auf: betsyjcole
This thread was marked as solved so if the solution doesn't work for you then you can start a new thread and ask yit again.
Nachricht 8 von 19
paramountcdc
ToanDN, this question was not resolved. Please unmark this question as answered since it places this post at the top of the search results and wastes people's time.
The question was: The Area Boundary command default is "Apply Area Rules." The questioner and I would like to know how to change the default to NOT "Apply Areas Rules," i.e., the Apply Area Rules checkbox should be unchecked when the Area Boundary command is initiated. If this is possible, the answer is probably some code to be added to the user's Revit.ini file.
Nachricht 9 von 19
als Antwort auf: paramountcdc
You replied to OP @Anonymous and asked me to remove the accepted solution? None of that make sense.
Nachricht 10 von 19
PDSF
I have this question too, and there has NOT been a valid "accepted solution" yet.
Nachricht 11 von 19
chlindberg
I also have this question.  The "solution" is not a does not answer the question.
Nachricht 12 von 19
mnskll
This is clearly not solved, again, is there a way to not have the "apply area rules" checkbox be enabled by default when using the pick line tool for area boundry? It doesn't work the way I need it to so I have to uncheck it every time, very annoying.
Nachricht 13 von 19
KevinHuntU5QPR
als Antwort auf: mnskll
Would like to reiterate this issue. I have 9 levels of area plans drawn with the apply area rules checked. How does one uncheck that for all previously created area boundaries.
Secondly, why is this a thing anyway? Why dont area boundaries just work like every other line in the program?!
Nachricht 14 von 19
dlacombeNCFKG
I also am looking for an answer to this question. It would save a lot of time if I didn't have to uncheck the "Apply Area Rules" box each time I go to draw area boundary lines. Seems like toggling this box ought to change the command's default mode, but I'm skeptical and will be surprised if there is a workaround.
Nachricht 15 von 19
SteveKStafford
You can disable the option via the Revit.ini file
Steve Stafford
Nachricht 16 von 19
betsyjcole
als Antwort auf: SteveKStafford
Thank you so much!  It took me a while to figure out how to do it - I've never heard of this, but it worked!
Nachricht 17 von 19
mans_karnekull
Can you please tell us how you did it? I tried adding the
"AreaBoundary_ApplyAreaRules=0" to the ini-file, but can´t get it to work @betsyjcole
Edit: So this is a new function in revt2024.1? To bad I'm still on 2022 in my main project.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=RevitReleaseNotes_2024updates_2024_1_Enhancements_...
Nachricht 18 von 19
AhmedDri
I changed the revit.ini file but it doesn't work, its always checked by default
Any help ?
Nachricht 19 von 19
SteveKStafford
als Antwort auf: AhmedDri
It's an option new to 2024.1 only (and newer).
Steve Stafford
