how to calculate total length of walls in quantity takeoff/schedule
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
tiho
10357 Aufrufe, 3 Antworten
I'm trying to calculate lineal feet of site walls in a takeoff/quantity schedule but not sure how. I can get areas to calculate totals but now Length parameter. ANy suggestions?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: tiho
Is this what you are after? If so, you just need to make sure that on your Schedule, the Length property has this setting (Formatting tab: Calculate totals & Sorting/Grouping tab: Footer > Totals). Hope this helps.
If this resolves your issue, please click ACCEPT AS SOLUTION to enhance the forum.
Nachricht 3 von 4
ennujozlagam
hello, you can refer to these LINK and LINK previous thread. thanks
Nachricht 4 von 4
tiho
als Antwort auf: Anonymous
yes, thanks. I actually figured it out right after I posted but thank you anyway. I had gone down the wrong choice of "Quantities & takeoffs" instead of wall schedule and the option to "calculate totals" was not available for the "length" parameter. Once I chose to create wall schedule it all worked like magic.
