Hello everybody!
I need a tool or Plug-in for Revit to calculate Building Gross Volume. This means that Revit should calculate
the volume from the exterior surfaces - walls, roof and floor in the Underground level.
I have tried so far with creating separate plan views with one big Room for the whole level (because only 'Rooms' have option for Volume and the 'Areas' are only for 2D measurements). But since the 'Room' exist in all views this generates a lot of errors.
Second solution was to make Masses afterwards, but for a more complex project and for Roof with Dormers and so on it is impossible to model every single volume again.
It is important to state that I need to schedule these volumes, because those documents are later given to Municipality with the whole documentation (I am in Germany) and it has to give also each measure - width, length and height.
I hope someone has a solution, because in this older post there isn't any:
https://forums.autodesk.com/t5/revit-ideas/building-volume/idc-p/8710325#M26437
A year or so ago, I needed to make a small solid model of a building so that it could be cast in metal for a desk ornament. (Stay with me here.) I ended up exporting the model in ACIS format, opening it in AutoCAD, and adding and unioning internal solids until it was one solid lump, whose volume was simply one of its reported properties. Perhaps you could take a similar approach.
Here's a possibly faster way that doesn't require finding and filling all the voids:
Good luck!
Thank you for the reply, Bill.
This idea could work, but we do not have AutoCAD. I was told that this approach can be implemented in Dynamo, but I am still not good at it.
I will continue looking for a solution.
