how to calculate formwork
5 ANTWORTEN 5
Nachricht 1 von 6
TomasoCardia
3984 Aufrufe, 5 Antworten
HI,
Is there anybody who knowsCaptura.JPG or have a method to calculate formwork?
I was thinking about using de paint tool (to differenciate the type of formwork on my ocnstruction) but then I can't hide it..
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: TomasoCardia
You could make the paint materials look like bare concrete in Hidden mode, and look different in Shade mode, by changing the color of the material's graphic tab > Shading.
Nachricht 3 von 6
SteveKStafford
I wrote a blog post describing schedules to calculate foundation insulation, which could be interpolated for formwork surface area at least. A comment added by a reader suggested a technique that was interesting too, using a mass to subtract the surface area of the concrete elements from the mass and arrive at a total surface area.
Steve Stafford
Nachricht 4 von 6
There is a plugin that can quantify formwork and any other material and you can configure it to follow POMI or any measurement standard.
https://apps.autodesk.com/RVT/en/Detail/Index?id=8582772410282720734&appLang=en&os=Win64#
Nachricht 5 von 6
TomasoCardia
als Antwort auf: ToanDN
Captura.JPGIs it possible to do Filters by material? In this way I can do a view with a filter formwork (colors) and other without it (grey)..
Nachricht 6 von 6
You assign different BOQ codes to Revit families and types and use calculation formulas for each linkage.
