A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
- Formatting tab: set the Area parameter to Calculate Totals
- Sorting / grouping tab: Sort by Department, Un-itemize every instance
Hi @ct_studio
Thanks a lot for posting your question to the forums! Has the solution suggested by @vitorbortoncello @ToanDN helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
