how to calculate clear area of column face started from beam face check pic insi
8 ANTWORTEN 8
Nachricht 1 von 9
799 Aufrufe, 8 Antworten
 how to calculate clear area of column face started from beam face  red lines in picturesdafasdf.JPG
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: Anonymous
For one instance or for all instances in the project? One way would be to paint the surface(s) to extract the paint:area into a material takeoff schedule.
Nachricht 3 von 9
als Antwort auf: barthbradley
when i paint face all area of  column face painted not the area which i wanna only sdsdfsd.JPGsdfasdfasdf.JPG
Nachricht 4 von 9
Don't understand, but you can apply paint to individual surfaces. If you want to change the extents of the paint on that one surface, use the split tool on it.
Nachricht 5 von 9
EDIT: Okay, I see want you are saying. The exposure on the inside face is what you're talking about. Disregard what I said then. As soon as this coffee kicks in, I'll be back. HA!
But, just to clarify...you say that those are Structural Framing families joining to a Structural Column family?
Nachricht 6 von 9
column 30cm x 60 xm   the wall thickness 20 cm  i wanna easy way to calculate the yellow area of column ,,,
Nachricht 7 von 9
column 30cm x 60 xm   the wall thickness 20 cm  i wanna easy way to calculate the yellow area of column ,,,            ((60-20)*height of column)asdd.JPG
Nachricht 8 von 9
Then yes, use paint as I suggested.
If this isn't working for you, my question remains: what families are you using to create this condition?  Looks like you're using walls to me. In that case, painting the exposure should work fine.
Nachricht 9 von 9
Paint the exposed surfaces with a material and create a material take off
schedule. There is a field called As Paint, use it to report the painted
area.
