I need to have plan view areas of roof surfaces noted. So, not the sloped ares (as if I need shingle area), actual plan view surfaces of different areas of the roof.
If the roof is 10m×10m in plan, I need to get 100sq meters as a result, no mater the slope.
I thought it can be done through "Area", but apparently not.
Also, how do I get my roof back after I start that command, the only way I can see is undo, but I must be missing something.
Here is my failed attempt if gif.
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Gelöst von EATREVITPOOPCAD. Gehe zur Lösung
You can create Area Plans
This plans tabulate plan view areas
Change the Area Plan Cut Plane to see the roof, or set Underlay to show the roof, then draw Area Boundary lines by picking the roof lines, then place an Area + Area tag inside each boundary you want to calculate.
Assuming the Level 4 is at the Ridge...
Yup, creating an Area plan is the solution. Thanks!
