I am working on a project and it says that bump-ups and bump-outs are encouraged. Is it possible to create these in Revit? If so, how?
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
can you be a little more specific? where does it say this?
almost anything is possible in Revit.
Hi @Anonymous
I see that you are visiting as a new member.Welcome to the Autodesk Community! ![]()
Are you talking about bump maps? Which version of Revit do you use?
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
I am building a shipping container house. I need make things like the pull
out sides of an RV.
You can model-in-place geometry in the project environment, or you could model face based families (that's the option I would prefer)
Hi @Anonymous
Check this screencast on shipping containers by Tracy Chadwick
This thread has some interesting workarounds on modeling shipping containers.
Let me know if this helps!
Viveka CD
Hi @Anonymous
How are you doing? I'm checking back to see if you've made progress on the shipping container model?
Feel free to add pictures if possible.Looking forward!
Viveka CD
When I need to make corrugated walls, I generally use a curtain wall. If you create the profile for the infill that is the same as the plan shape of the corrugated wall material (starting and ending with a piece that is 1/2 the length of the others so that it tiles properly) and using no mullions, then the wall will appear as a solid panel.
Carefully consider whether the corrugations actually need to be modelled- or can they just be represented with a surface pattern. Always consider whether all those extra faces of geometry (which have an overhead) are adding value
