How to Build House on Stumps?
aliraza124543
aliraza124543
I need a little help/guidelines regarding a house building on stumps. How to model the deck in Revit. And what factors should be considered for it. Any related material or plans would be greatly appreciated...
kadmonkee
treat the stumps as if they are your foundation walls
set a level grid for each level needed and create the views for each level then design you house.
if your stump heights vary then create a level for each stump height
set a grade level then set levels as needed going up.
roof level = 25
2nd floor = 18
1st floor = 10
Stump 4 = 3'-0"
Stump 3 = 2'8"
Stump 2 = 2'-0"
Stump 1 = 1'-10"
Grade = 0
worst case scenario is all your stumps are different heights you would need to block up to the heighest stump then place your structural deck @ that elevation.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
