How to build 2 dimensional curve objects in Revit?
2 ANTWORTEN 2
Nachricht 1 von 3
341 Aufrufe, 2 Antworten
Hi all,
I'm a beginner in Revit. I'm was trying to build a bathtub with 2 dimensional curves using sweep but failed.
Please see below for the geometry. I guess I cannot use sweep as the sectional profile change? Please help if there are other ways to build this. thanks :leicht_lächelndes_Gesicht:Capture.PNG
2 ANTWORTEN 2
Nachricht 2 von 3
AutoCAT95
als Antwort auf: Anonymous
Hi @Anonymous !
At the beggining I suggest you to create objects like a tank as a families. The tool you might need is a Create -> Extrusion and then use Draw option to design whatever is your desire :). Play with this and im sure you will get what you want.example.jpg
Nachricht 3 von 3
It can be done by joining a few extrusions and some voids. Are you designing a custom tub? If not, just find a family from a manufacturer and use it.
