How to backfill slope retaining wall
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
linkboy
510 Aufrufe, 3 Antworten
Working on site with sloped retaining wall, after moving site/building pad close to the retaining wall, the backfill is a vertical cut not quite follow the sloped wall. A way to infill the triangular void?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: linkboy
Create a sloped building pad matching your sloped retaining wall.
Nachricht 3 von 4
starfish815
als Antwort auf: ToanDN
You should show the couple of steps needed to make that.
It's two building pads is it not?
Nachricht 4 von 4
als Antwort auf: starfish815
Correct. A flat and a sloped building pads
