I try to assign a global parameter to a number of dimensions.
If I understand right, the "Label Dimension" Widget should be available after selecting a dimension as shown in the following screenshot:
In my case, however, even after selecting a dimension it is not visible:
Am I missing something?
Dietrich
Gelöst! Gehe zur Lösung
Gelöst von semko_dm. Gehe zur Lösung
Sorry for posting twice. I got an error message after hitting the [post] button - and the advice, to try again in a couple of minutes. That's what I did...
By the way, is there a way to erase a message after posting it?
Hi!
Global parameters are available only in Revit 2017 and in Revit 2016 R2. What version do you use?
Also, global parameters are unavailable for Revit LT.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Dmitriy Semko.
Hi Dmitriy,
Hi, Dietrich.
You can find a complete comparison <on this page>.
Also, take a look <at this page> its include some information about Interoperability between Revit LT and Autodesk Revit.
Hi Dmitriy,
Thank you. I have searched the comparison page before - but obviously overlooked the part about global parameters...
Features > Advanced modeling > Global Parameters: supported in Revit - but not in Revit LT.
Too bad...
Thanks again,
Dietrich
