How to apply material to generic model?? Please Help
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
7868 Aufrufe, 4 Antworten
Hello everyone, I am using a generic model family template. The model was imported as .sat. The problem is Revit won't let me assign materials. The option is no where to be found despite my attempt to add material parameter. Please find the file in the attachment. Your help would be greatly appreciated.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Use the Paint Tool and apply Paint Material "PARAM" to Faces of SAT .
Nachricht 3 von 5
dferreira-blackwell
Open the family--->go to modify tab-->Geometry Panel-->select paint-->apply as you want. it works I tried.
Nachricht 4 von 5
Thank you both very much! It worked out beautifully.
Nachricht 5 von 5
als Antwort auf: barthbradley
Hello sir is there a way that i can apply one material to the whole generic model project?
can i use the dynamo tool to select them once for all and apply the material directly instead of doing it one by one ?
