Hi everyone, a while ago I managed to configure it, but I need to do it again and I cant remember at all!
Basically, the floor plan of some higher level should display elements that are one or more levels below in light tones.
I don't talk about underlay levels.
Let me show:
this is the floor plan without any configuration.
and now the floor plan with de right configurations:
(I dit it manually)
I vaguely remember that it was an option within the settings: Manage-> Object Styles
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Set the View Range Bottom to higher than the Lower Level, but View Depth lower to capture that level, then go to VG > Lines > and change <Beyond> line type to halftoned.
